Archive
How do I remove the sound driver to computer?
I'm going to replace my sound driver because its has low quality of sound. I want a high definition sound. My problem now is I don't know how remove it from my computer.
My sound driver is Vinyl Audio Deck. And my other reason why I want to replace it is because the sound driver too old and no downloadable driver now.
But my friend advice me in order to replace my sound driver is to replace my sound card first and it needs to be compatible with the system.
How will I remove...
Read more
User accounts problem, how will remove it from a computer?
I set a username and password to protect my computer from other users in our office but one day I didn't know that I will got sick and so I don't go to office. My officemate called me to ask some files from me and it all saved in my computer that has username and password. She asked me what is the username and password of my computer to be able to open and get the files that she needs. But unfortunately I forgot what I put in there because...
Read more
I have a laptop that was bought few months ago. Included with it is a windows 7 starter installer as part of the package. Free installation of the OS is also a part of their service. After a few months my computer was devastated with viruses and starting to run so slow. I decided to install a fresh OS for my laptop. The problem is that the driver is not included on the package, I just don’t know if they just forget to include the driver or it was not part of the package.
I bought my laptop far away...
Read more
How will I know if the computer is already overloaded?
I have an Intel Celeron with 80GB hard drive, 512 RAM, 256 video card, and Windows XP operating system. I would like to ask how will I know if my computer is already overloaded. Sometimes, when I used it by just surfing in the Internet, it moved very fast but when I was already playing, I noticed that it ran slowly and  "LAG" or it paused  for a second.
Is it overloaded already or not? Is there a way to know if it is just really a  lag? Please help.
Read more
I could not run Windows Update on my Windows Vista. Every time I try to update, it would only fail with and Error 80244019. I think it has something to do with reaching the update server, however this doesn’t explain the problem.
I’ve tried my friend computer which also installed with a Windows Vista and update it take a couple of minutes but the update doesn’t fail. I check if I can connect to the net and thinking that it has something to do with my Internet connection but everything was fine.
I’ve also tried my own tricks like resetting the...
Read more
Hello!
I just want to know how to remove and delete temporary program files.
Here's how I did;
I did the disk cleanup but the files are still there. I don't know how to remove or understand disk cleanup. My friend mentioned only disk cleanup.
If I click the box of the temporary file what happens next? Does the disk cleanup delete all the files? But why is it the files are still in the drive C?
I want to know all the details so that I will be the one to do the action.
Do you have...
Read more
Spools.exe is a virus or not?
I was fixing my sister's computer and when it opened up and something popped up and it is spools.exe but its not responding. So I clicked Ok button in order to remove it from my screen because I was trying to fix something and going to play later.
When its gone I did what I have to do but after 15 minutes of using, it pops up again. I don't know what to do anymore. The Antivirus cannot detect even removed it permanently from the computer.
I'm so clueless on how to remove the spools.exe from...
Read more
Computer is running too slow, how will I fix it?
When I opened my computer now I noticed that it runs so slow and I don't know what happen.
The last time I used it was okay and running fast. I checked the hardware inside the CPU but I think there is no problem and okay. I check the hard drive if how much free space and it has 20 GB free space. I'm really curious why computer running too slow.
Can someone knows this kind of problem? And how will I fix it?
Please help me.
Thank you very much!
Read more
How can I partition the hard drive?
I'm using an Intel Celeron computer, with an 80 GB Samsung Hard drive and Windows XP operating system. I reformatted it and decided to partition my hard drive to be able to separate some important files that I want to store in my computer. But the problem is, I don't know how to partition a hard drive. I just know how to reformat it but I don't know much about the partitioning. I tried it but there's a problem. It loads very slowly and I always have to restart it because of that.
What...
Read more
How will I remove the virus on computer?
I was using my computer then suddenly a virus popped up on my screen. It says that my computer has detected a virus and it's a harmful one. I'm trying to close it but it always comes up. I restarted my computer to see if it's going to remove and then after I restarted it, I waited for about 15 minutes before I started what I was going to do. After that it comes out again.
My Antivirus is Avira and it strongly detects the viruses but it depends on the...
Read more
