Archive
Hey. I am Arthur and I am new here in TechyV. I just need some help with my laptop which is already a year older. My laptop is an HP one.
No recent change was made, but I noticed that it says that my adapter is not plugged. I checked the cabling and all and seems like all are in its proper places. The adapter’s light is also turned on.
Seeing the setup, it is just the way it is from the first time I have used it. The only difference is, it says that it is not plugged in, but...
Read more
I am running a training center for over two years. To provide lectures, I have been using a projector with my Dell Inspiron 1545 laptop.
The projector was fine and never having any disturb. Last week I have replaced the operating system on my laptop with Windows 7 which was running on XP previously. After then my projector is not working and I can’t see any display. I have applied all the previous key options but getting no display. I have checked the video driver which looks fine. I can ensure you that there is nothing wrong with the projector because it works fine...
Read more
First of all I would like to thank the admin to run such a useful site and the experts are doing a great work too. Here is my problem:
Internet explorer application error
iexplore.exe - Application Error
The instruction at "0x01cc3812" referenced memory at "0x01dbdf8c". The memory could not be "read".
Click on OK to terminate the program
I am running Internet Explorer 8 on my laptop which is running on Windows 7. My Internet Explorer showing an application error in the middle of browsing and on clicking OK button it crashes immediately.  I remove some of the add-ons but...
Read more
Hi All,
My sister asked me to open a Microsoft Excel document in our desktop which contains her passwords and accounts. She forgot the password for one of her accounts that she need to logon to. The file is password protected, and I just know that it should for security purposes.
Now, my problem is, the password that she gave me is not working. I already tried twice and I am not sure what will happen if I got the third incorrect try. Anyway, my sister is waiting for my reply and I told her already about the password not working....
Read more
Dear Techys,
I am having trouble with my HP G7000 laptop. The problem started after a reformat was done. I just wanted to do a clean start with my laptop, but after doing it, my laptop is a mess.
The problem specifically is in my Windows Explorer. My laptop is running on Windows Vista SP2. Believe me, It still got lots of memory. Whenever I am using 3 or more application programs, then I would open Windows Explorer, then my Windows explorer will suddenly froze. On the top of the box, it would say Windows Explorer is...
Read more
I think my computer is infected with malware or a virus that I cannot define. This happens after downloading Adobe Flash Player Update which I think is a legit version from Adobe itself, by the look, you really can't tell that this is some sort of a virus. After downloading the update, my computer shuts down and I could not open it to my windows again.
I open it again, and I can just reach until the Windows XP loading window. After that it restarted again then an error appears that my windows failed to start. I hit the F8...
Read more
I signed up as a publisher on AdHitz a couple of months ago. I was so busy at my work that I didn't get the time to check how to earn using AdHitz ads. Yesterday was my rest day and I had a spare time to look into this website.
It says that I should just paste the code generated to my website and that should be fine. The problem is that after I paste the code into the header of my WordPress site, the AdHitz banner doesn't show up on my site. I don't know if I...
Read more
Hi TechyV Users,
I am currently having an issue with creating an account in Hotmail. I need to create several accounts as I will need it in a project. As I have browsed through the requirement, it should be a Hotmail account, so even though I am encountering an error, I should resolve it to make progress with my project.
Kindly see the screenshot below for my encountered error.
Windows Live
We're fixing a temporary problem with Windows Live ID sign-up. Please try again. If you continue to get this error try again later.
It is an Error 100...
Read more
I have a Dell notebook located inside my room and a desk in our classroom. I am using Remote Desktop connection access from my desktop to my laptop. It worked well for a while, but when I returned me home after a long vacation, suddenly, remote access no longer works.
No one uses my computer, and I do not touch anything. I can see my desktop file sharing, which means my network works. I can not connect me, via connection to a remote desktop.
This is the error I get.
Remote Desktop Disconnected
The authentication...
Read more
Hi!
I installed IIS on my Windows XP Pro PC, so that I could test my website before publishing it using MS Frontpage 2003. However, when I tried to open http://localhost, a box came up asking me to enter a username and password. I have no idea what username and password to be used here. I don’t remember using any username and password before because I have admin rights.
Do you have any idea why I am being prompt to enter a username and password? This is the first time I encountered this issue. Please help me if you can.
Anna Brooks.
Read more
