Archive
Every time I play games in my desktop computer, the screen turns blue after maybe 10 minutes of playing. It happened several times already.  Please help.
Read more
I want to change the file system of my drive without formatting. I experienced FAT32 is working very slow with Windows XP. Someone suggested, to change the type of file system. My question is “How I can convert Fat32 File System to NTFS File System of a drive without formatting?
Read more
Hello Everyone,
I have a business Centre and my all IT base platform is on Mac. I’ve a Mac OSX Server. It’s a standard 2008 R2 domain. I’ve two partitions, one is server and another is Public. I want to share public with all my colleagues. I popped onto server admin Volume and created a share and attempted to share it via auto mounting, ensuring that I had moved the group students into the permissions, but it won't work. I've tried in different ways but failed to fix it up. Any solution please let me know.
Arifuzzaman
Read more
I am feeling very happy to see this, very informative and valuable site. I have read nearly about 50 questions and implemented the solutions. It’s very helpful for me to work and understand the computer on hardware and software both levels.
All experts have done very appreciative work. I also have a question and want the solution. I want to print a document in booklet form, in Office 2007.
Guide me through, so that I can get the desired result.
Read more
My cousin told me that it is better to have a 32-bit operating system, since you will find a great range of applications and software that are compatible with the platform. As for 64-bit platform, you have to be certain that the software you like to install, is compatible with 64-bit platform. I somehow got his idea but how exactly can I tell, which one I am using? I am using Windows XP Home Edition SP3.
Read more
How to take a screen shot, then put the capture item to word file? Is there a tool or an in built way to do this? Should I save it first? Please help.
Read more
Dear All,
Recently I've purchased an Apple MacBook Air. As you know that, MacBook Air has no Optical drive, but it has an option for remote DVD. So, I've tried using remote DVD. I inserted a disk in another Macintosh computer and turned on my Airport connections and tried to connect with another Mac, but it's not working. Is there any solution? Please help me. Thanks.
Chowdhury
Read more
I have an issue, while I am working with a team. I want to secure my data from being copied to any type of USB flashes. I just wanted to get the settings or information of having all the USB Flashes write protected, when I use them with all the other computers in my office.
Read more
I want to speed up the working of the processor. Mostly, when I am working with Internet Explorer and Mozilla Firefox, my processor responds very slowly. Let me know about the problem, that may cause this issue or any solution for this. I want to speed up the working of processor while I am working with more than 5 applications at a time. Can someone guide me on this issue?
Read more
I am using Windows XP. I have a machine that has a hard disk and a CD-ROM drive. I want to make the CD drive as a slave disk and the hard disk as a master. How do I do this?
Read more
