Archive
I am using a EJB project to access my MySQL database. I keep getting an error, "more than one row returned" when I run a select * from budget table.
Read more
I have some difficulties that I hope one of you can help me solve them.
I have been using Linux Fedora 7 for quite some time now and it’s working very well without a glitch. I want to use Yahoo Messenger instead of other IM software because I want to use my cam as well. I have used Pidgin before but have no clue on how to use webcam together with the chat software. Don’t get me wrong. Pidgin is wonderful and all, but I really need to use webcam along with the chat software.
I am attempting to create an Index on one of my tables. I keep getting "operation timed out". Why is this?
Read moreI am using remote desktop to login to my office computer. I have a set of files on my USB disk. How do I access the files within remote desktop ?
Read moreI am setting up a disaster recovery box for the production website. For this, I took a backup of the production MS SQL database and restored it into the DR box.
When I run the application, I get an access denied message. I checked the database and I found that the user mapping is gone!
How do I restore it ?
I have an Excel sheet containing about 1,200 rows. Each of the rows has different customer information. I want to know how many of them have dues.
Problem is the number of rows is not fixed. They may vary. So I can’t count the number of empty cells and just minus it from total rows. Do you have any suggestion?
Read moreHi,
I am learning Excel VB programming. It is quite easy. But I don't get how to use custom function in here?
Public Function gradeCal(gpa As Double)
If (gpa >= 5) Then
Return "A+"
ElseIf (gpa >= 4) Then
Return "A"
End Function
But its not working. What is the proper syntax of returning some value from a Excel function?
Read moreHi everyone,
I am doing some work with Excel. I am not much familiar with VB but the Excel macro seems easy and interesting. I have yet used MsgBox and buttons to do almost everything. The Excel sheet was the main window which is used as a form for hosting the other stuffs.
For example if i need 3 data to input I use something like
x = InputBox("enter the value", "Its the title")
3 times.
Now I think it would be cool to have my custom popup messages/forms for doing all these. But how do I do this? Please help.
Read moreHi
I have been playing around with Excel a few days. It is really a nice tool. I can do a lot of calculations here with less effort. I have also heard that it is possible to do some programming with excel too. So i thought i will try.
Here is what I want to do first.
My present sheet has 7 columns each are having a value (cash amount) in each of them. The 8th column holds the following equation:
=SUM(A1:C1)/3+SUM(D1:E1)/2+F1+G1
So it gives the summation of the left 7 columns. The equation changes from A1 to A25 , depending on the row number.
The problem is that it is...
Read more
