Archive
Hi all,
I got this error today, when I connected my iPhone to my laptop. Is there a known fix for this?
I Googled, but could not get any solution. iTunes could not connect to this iPhone because an unknown error occurred.
iTunes
iTunes could not connect to this iPhone because an unknown error occurred (0xE8000065).
Janvi
Read moreI just updated my system to SP1 and now I have some weird problems.
- First problem is that (re)booting my system takes about 5 and sometimes 10 minutes.
- The second problem is with the Sound Mixer, it says the Audio Service is not running but it is. However I managed to solve this.
- The third problem appears to be a corruption of the build in "Open Command Prompt Here" option. Every time I right click on my desktop or inside a folder I see this weird context menu item "CMD". If I select it I'm getting a "This file does not have... Read more
I have tried everything so far, and nothing helps.
I have installed the IntelliPoint 6.2, but it doesn't work. My Sony Vaio Vista recognizes the devices, but I can’t move it or use it at all. When I go to its properties and click on Buttons the following message appears:
Some mouse settings might not work until you connect a Microsoft mouse to a USB port on your computer or set up a Microsoft mouse that uses Bluetooth technology.
I already tried to configure a Bluetooth device on a Windows-based computer.And my computer recognizes this mouse, and tells me that the recognition...
Read moreI am backing up my Mac Pro to a backup server (a Power PC G4). Both are running OS X 10.5.4. The version of Retrospect is 6.1.23 and the client is 6.2.222. The backup server says that the client is "responding,", but I continue to get the "Waiting for backup media" message over the past 24 hours. There is a lock icon on the drive that I want to back up.
I am here to ask a technical question about my PC. I have been using Microsoft Windows XP since 2008 but I have not seen an issue with my operating system as it is being faced by me right now. The problem I have got with my system software is that my folders or even drives us to open without any follow-up.
Mean, whenever I open any folder or I click on any local disk drive, it opens in a separate window rather than in the same window. Suppose. If I would like to open five different folders in a single drive then they...
Read moreHi all,
We have RAC installed on 2 T2000 machines. Solaris 10, patched IPMP for failover on all interfaces, NetApp NFS for data file, voting disk, etc. Oracle installation, binaries, etc. are on local disks.
All configurations were according to Oracle/NetApp docs. And there were no issues during installation. When we try to create the db using dbca, the process hangs during data dictionary creation. There is only one error message "Warning: aiowait timed out x times". All the NFS partitions are mounted force direction, and we have tried to disabled in Oracle.
We have also tried without force direction, with no...
Read moreHello members,
I got a problem with my system's CPU fan recently. It stopped to increase its RPM when under load . So, I can't use my system for heavy duty works which is obviously a big problem for me.Because, my system is getting too hot when I use it for heavy duty works. It actually occurred after I upgraded my video card to a GTS 450 from the old video card (8800gt).
Kindly, help me in this. Thanks.
Read morePDF files are a good place to store data. PDF files are non-editable which makes it more stable. But it can be editable using some kind of software so i am thinking about the security of the PDF files. Is it possible to use password protection to PDF files? If it is possible then how can it be done? I like to know the procedure of the process.
PDF files are a very good format to store data inside it so important data can be stored if the Password protection can be applied. This will help to handle very secret...
Read moreWhat is the Static IP address? What is the Dynamic IP address? I have heard those terms but never understand what are those things. I basically know that the IP addresses are the numbers which is assigned to a user to identify him in a network.
I have used LAN so I understand only these things but in the Internet I don't know how the IP address works.
What are the differences between the Static IP address and the Dynamic IP address? Is there any advantages of Static IP addresses? And similarly is there any advantages of Dynamic IP addresses?
And please...
Read more
In Windows operating system, in every version I have operated. Till now I haven't seen the System32 file. What is this? Why this is named like this, why the "32" is given in the file name? What is it's job? I have seen that if I delete this file, the system fails. Why? Why is this file is so important and if the file affected by any Virus what happens? Is there any way to repair this file? And is there any way to replace this file if it's deleted?
What should I do if the system32 file...
