Virtual Box Networking inside Linux workstation
I'm new in using Virtual Box and wondering, if you guys can help me setting up in Linux. I'm currently using Mandriva for the Linux workstation.
I have downloaded and installed VirtualBox, without a problem in Mandriva. I don't think it would be a problem, if I'm using DHCP. But the problem is, I'm using IP static on the network. So to connect to the internet, I have to setup DNS inside VirtualBox.
I have tried assigning IP static inside the VirtualBox workstation, but it cannot connect to the internet. The internet connection can work properly on the host though. I'm using Mandriva as the host and inside the VirtualBox, I'm using Ubuntu.
I have tried to change network setting, so many times on the Ubuntu side or on Mandriva side, but still it is not working. I have installed the Virtual Box, then re-installed VirtualBox again and again, but apparently it doesn't solve anything.
My big goal is to try joining the Ubuntu workstation to the Domain. I figure if at least the Internet connection can work properly using network LAN, then it won't be hard to join it to the Domain. Unfortunately, I can't even make it work to connect to the internet.
Suggestions and ideas are welcome and very appreciated.
James
