No of visitors who read this post: 2593
Type: Question
No votes yet
I am receiving an error message while trying to uninstall certain programs like RegClean Pro. The error message stating certain file are missing and could not continue with the uninstall process. How can I continue with the uninstall process?
Comment viewing options
# Comment Id: 44973
Hi Rochelle,
You can try to insert the installer CD first or make sure the computer have the installer file of RegClean Pro then try to uninstall.
If you are still unable to uninstall, you can try to delete the folder on the application folder. To do that, go to My Computer > C Drive > Program Files > Look for the RegCLean Pro folder and delete it.
Another option you can try to do is to delete the file directly to the registry. To do that, go to Start > Run > Type regedit > go to HKEY_LOCAL_MACHINE > SOFTWARE > Look for the RegClean Pro folder and delete it.
