No of visitors who read this post: 251
Type: Question
Author: Trish Martin
No votes yet
All sites described the specifications of the Samsung Galaxy S 3, although some author tells that it was still under development at Samsung Lab and finally will be release this June 21st. Samsung Galaxy S lll has a battery of 2250mAh.
How does Samsung Galaxy S III have a long-lasting life battery?
Samsung battery        samsung galaxy S III
Comment viewing options
# (Solution Accepted)
Hi Trish,
I understand that you are concern about Samsung Galaxy S III's long-lasting battery life.  Well, I've done my research and this is what I got.
First, Samsung Galaxy S III's battery is not 2,250mAh but 2,100mAh.  So, does it have a long-lasting battery life? The answer is YES. It has a total of 11 hrs (3G) talktime,up to 385 hrs (3G) standby.  How's that? Anyway, you must also consider the applications you running.
Second, It has been launch in Asian Countries dated May 22, 2012. It was offered to TELCOS on the 24th of May. I hope that answers your query.
Keep me posted!!
Cheers,
Prima Oist
Hello Trish Martin,
I also done my research and Prima Oist is right the battery of Samsung galaxy s III is 2100 mah and not 2250 mah. As what I have observed I like to use Samsung brands whether phone or laptop because it has usually a long lasting battery life. It is very advantageous on our part. According to the article I have read the battery of Samsung galaxy III is excellent.
samsung galaxy
