Internet Explorer have stop working
I reformatted my computer. When I ran the Internet explorer to check on my internet connection, it suddenly stopped working and terminated. What is the problem this time?
Answered By 590495 points N/A #100936
I’m not sure if you can uninstall Microsoft Internet Explorer because it is a preinstalled application in Windows and it is the default web browser of the operating system.
And normally, default applications can never be uninstalled or removed from the system. If you force to uninstall it using any third-party uninstaller software, I’m not sure if it’ll work and might just make your system unstable and would lead to formatting your hard drive and reinstalling Windows again.
The best solution here is just to use a different web browser like Mozilla Firefox, Google Chrome, Opera, Safari, Netscape, and others. You may also try checking your computer for any possible errors.
Use a disk utility application to check the system. Maybe there is only a problem in the file system that can be fixed by a disk utility tool.
