A K Azad
35 points
Posted on - 09/26/2016
IPhone can be used to send emails using mail apps. But sending large data can cause loss of data or do not send the email. This problem’s solution is Dropbox. It allows you to share files no matter how large they are. how to send large video files on IPhone using Dropbox?
R Ocampo
10 points
How To Send Large Video Files On iphone Using Dropbox.
The steps are as follows:
1) Download the Dropbox app on your IPhone.
2) Search the file you want to share.
3) Click on the document and select share button.
4) Click on copy link.
5) Go to your mail app. 6) Compose a new email.
7) In the body, tap to bring the pop-up menu.
8) Click on paste.
9) Fill all the information and click on send.
Other way is as follows:
1) Download Cydia app and open it on your IPhone.
After the installation, you can send large files via message, email or any other way without an error message.
