No of visitors who read this post: 543
Type: Question
No votes yet
Hi guys,
I hope all of you will be fine. I have created some CD+G files using Karaoke software and now want to play this format in media player but it is not supporting it.
I am worried as I have spent a lot time on developing those video files with high graphics and smooth background lyric music.
Does VLC player play CD G on PC?
Any help will be most appreciated.
Comment viewing options
# Comment Id: 137008
Mr. Kristopher Fran,
Dear VLC Media player has a lot of plugins.
It can support many file types to play them smoothly. VLC player can play your files if you have installed a proper version of it.
Some older versions of VLC media player have some problems with some file types.
You should try to use a later version. I suggest you to download VLC Media Player 2012 version.
You can download it from this link.
Download Link.
I hope this will give better results to you.
