Can’t Publish App Using Adobe!
Hey, Techyv!  I have created an Adobe AIR application that I would like to publish.  I have been trying to publish my application for a week now but haven’t been able to successfully do so.  When I click “Publish AIR File”, I get an error message.
Can anyone help me?  I have been trying to publish my application for days now!  Advice is appreciated! Thanks!
Adobe Flash Professional Error
Error creating files.
Error occurred during initialization of VM
Could not reserve enough space for object heap
Could not create the Java virtual machine
Compilation failed while executing: ADT
Best Answer by Mamun
Answered By 0 points N/A #86674
This is very much complex to work within Adobe,Adobe Flash or with Adobe Reader. You have to need license before you have wished to publish your unpublished work at Adobe Air.Certainly Adobe Air itself an application that has to be downloaded for the file adopted by the Adobe Air.You must addressed to Adobe Air on the address bar and click.You will discover Adobe Air software on the monitor.Click on Adobe Air.Now this is the main place from here you can deal for your expected license agreement to get your Adobe Air file would be.
Answered By 0 points N/A #86677
I've got the same error and wasted most of the day to find a nice solution.
We need to add -Xms64M -Xmx512M java params here, but the way Flash invokes java makes it nearly impossible.
Here is my java wrapper, that deals with this error. Just install it to default location and you should be able to make IPA.
