Why do I get a warning when using Modern_Airports/Facades/modern3.fac?
I tried using the brick system to build an airport but unfortunately some insignificant error gets in my way. It says, ”Error loading the scenery package: Resources/default scenery/airport scenery/
The scenery may not look correct. Please see the log.txt file for detailed error information.
(REN_facade.cpp:694)Resources/default scenery/airport scenery/Modern_Airports/Facades/modern3.fac:18:
This facade uses a roof object that is not inside a roof. Please fix this!” The message is obviously too long for me to understand. What am I supposed to do? Can this be fixed?
