Where can I buy a Flashboot registered version?
Hello there! I want to buy a Flashboot registered version on the internet.
I still have the trial version that is going to expire soon, but it won’t come up the day I needed it.
Can anyone help me?
Thank you!
Best Answer by Randolph Brownlow
Answered By 0 points N/A #164860
Hey,
I have understood your question as you are demanding for the full version of flash boot registered version.
You can directly download it from the internet and it is a file of 30mb that too it is a full version
I hope this will solve your issue.
Thanks & Regards,
Gillam Janetj
Answered By 5 points N/A #164862
Hello Lowry
Every trial software, usually has a purchase option. After your trial has finished, a new window pops out reminding you that and offering you the option to buy the software. If you have installed only the trial version without a purchase option that this is not the case.
You can download FlashBoot from the link I have provided you with, install it and then purchase it. You will see the option right after the installation finishes.
FlashBoot 2.2
I hope you will find this information useful.
Randolph
