What Is Can’t Find Dinotify Exe Found Error
My home computer works just fine. Out of nowhere, it has started throwing around dinotify exe whenever it feels like. I cannot seem to work this out. I do not know how to remove this error. Is it even possible to do so?
Answered By 20 points N/A #321727
The dinotify exe is a Windows file which is part of the Windows System Files. It is responsible for running the software you use on Windows. The reason why you might get this error is that somehow you have corrupted this file. It is an essential Windows file, and therefore, your computer keeps throwing this error message at you.
In order to remove this error, first of all, you need to check your antivirus. Sometimes, your antivirus can interfere with system files. Remove the antivirus and then run the system restore in safe mode. You need to shut down your computer. Turn it on and press f12 to get boot options. Select safe mode. After the system boots up, turn on System Recovery.
