“TurboTax Deluxe 2010 Error Code: 10495 “
Hey everyone,
I have installed updates for Turbo Tax Deluxe on a regular schedule for the past few months. This prevented many errors until this one here. I installed the last updates four days back, I think. Does somebody know what to do to fix this? I guess regular updates can't prevent everyerror. Thanks guys.
Error Code: 10495 Oops, we cannot start a return because There is a problem with the TurboTax Installed tax forms. We cannot determine The tax year. Please re-install TurboTax. Exiting TurboTax. Error: 10495
Error Code: 10495
Exiting TurboTax.
Error: 10495
Best Answer by The score
Answered By 80 points N/A #96651
Hi Annie!
Have you tried reinstalling Turbo tax again? If not, try reinstalling it. Don't just reinstall and make sure you remove the application on control panel (add/remove program. You need to uninstall first before reinstalling it again.
  • Click start > control panel
  • Look for add/remove program
  • Choose the program you want to uninstall or remove
  • Click remove
If you are using CD to reinstall it, make sure that the cd is clean and then copy the entire cd into hard drive folder. Go to this link for manual updates after reinstalling turbo tx. Restart your computer after reinstalling for the changes to take effect. Have a great day and happy weekend. I hope it helps.
Zorian
Answered By 5 points N/A #96652
I can solve your problem just reinstall the Turbo Tax, but the folder of the tax is not pretentious when reinstalling the application and then follow my step or instruction below:
  • From your desktop simply select the start menu in your taskbar to the left side of your screen.
  • Select the control panel just click it.
  • If you're using Windows 7/vista, simply choice Uninstall a Programs.
  • If you're using windows XP, just double-click Add or remove Programs.
  • You just search or look the Turbo Tax, and then uninstall or change a program just click it.
  • From the Turbo Tax screen you simply follow the steps.
  • Then after you follow the steps simply restart.
  • Install now the Turbo Tax, then leave the CD inside the CD-ROM during the installation.
  • After the installation, simply modernize the Turbo Tax Deluxe 2010.
Ben
Answered By 15 points N/A #197325
Hi Scot,
The error can be resolved by reinstalling the new Turbo Tax software.
Follow the following steps to perform reinstallation:
A) Uninstall the Turbo Tax 2010 software from the system
1) Close Turbo Tax if you are running
2) Select 'Start', Select 'Control Panel'
Select-Control-panel-through-start-menu
3) Click 'Program Features', Add or Remove Programs', Click 'Uninstall a program'
Uninstall-program-through-Add-Remove-Programs
4) Select the Turbo Tax 2010, Click 'Remove' button
5) In the 'Repair/Uninstall Turbo Tax' screen, Click 'Uninstall Turbo Tax' button
B) Reinstall the Turbo Tax 2010 software
1) Close all browser windows and disable firewall
2) Insert the Turbo Tax 2010 CD into the system
3) Click 'Start', Click 'All Programs', Click 'Accessories', Click 'Run'
4) Click 'Browse', Double Click 'setup.exe' file
5) Click 'OK'
6) After the installation is completed, Restart the system and enable the firewall settings
Answered By 0 points N/A #197328
Hi John,
It looks like there might be some problem with the installation of TurboTax or you have recently performed updates on the software. The best option here is to re-install the software. Before you do this, I suggest you first uninstall the current installation by going to Control Panel > Add/remove programs. Uninstall completely including the user preferences and files. Re-boot the machine and install the latest version of TurboTax.
Answered By 30 points N/A #96653
You need to reinstall the turbo tax again.
If you are installing from CD then you need to copy the installation files to the hard drive in order to reinstall turbo tax.
Go to the below website for step by step procedure.
Step by step procedure.
If the problem still persists then you need to forcefully uninstall and reinstall the software.
Click on the below link to know more.
Forcefully uninstall and reinstall.
Thank you.
Answered By 0 points N/A #96655
I have seen this error message before and you are right, something might have gone corrupted. As suggested you should reinstall Turbo tax. If you still encounter the same problem you should do the manual uninstall and reinstall of the program.
You can follow the steps here:
We got ours fixed by doing the manual method.
Answered By 5 points N/A #96656
As Turbo Tax offered for a fix, uninstalling and reinstalling the software will get this error solved.
However, there are some instances that after doing the mentioned routine, you may still get the same error.
To avoid this from happening, here is what you can do.
Uninstall the program first. Make sure that there are no other Turbo Tax files left in your pc. If you have a scanner for hidden files, run it to make sure that your computer is empty of it.
Now, check your Turbo Tax CD if it is clean.
Re-install the software using the CD and after installation, run a manual update for your Turbo Tax.
Open this link to find the latest updates.
Answered By 80 points N/A #96657
When you get the error code 10495 using your Intuit TurboTax program, it means that there are files missing or damaged by the installation process. The work –around to get this fix is to have the program uninstalled then reinstalled. In case your installation was done using a CD, please make sure that you have a clean copy of the entire program on your hard drive and then make the installation from that location.
Once you have it reinstalled, make sure to get the Manual Updates from
Manual Updates for TurboTax 2008-2012 Federal Tax Products
In any case that reinstalling it does not solve the problem, then you will have to uninstall and reinstall it by force. To do this, you may visit Forcefully Uninstall and Reinstall TurboTax for the step-by-step procedures.
Answered By 0 points N/A #96658
So it seems that reinstalling the turbotax program was the solution. Though it takes time but worth the effort. I was able to finished my tax return. Thanks for the help.
Answered By 80 points N/A #96659
Glad that you are able to submit your tax return in time. Don't worry about it. I'm so happy that I was able to assist you! Take care.
