Suggested Device: Server Room Temperature Monitor E-mail.
My server room gets heated up beyond the optimal temperture range. I need a device that will alert me when temperature of the server room increases. Can you suggest any server room temperature monitor email device?
Answered By 0 points N/A #177904
There are many sensor devices which you can use for server room temperature monitoring and control. Some of them are:
X-310 is a web-enabled programmable controller. It works as follows:
When the temperature of the server room exceeds the optimal range of temperature, the alarm rings, and an email alert is sent.
X-300 is like a web thermostat. It consists of humidity sensors. It incorporates special features like email alerts and logging of temperatures. You can also use sensorProbe2, Computer room temperature guard and many more.
