Solving The Error Code 0f00 0244
I was suggested to do the medical specialty hollow on my disk. It contains the error code 0F00: 0244, which also indicates the seasonal. DISK_0-BLOCK 27540752 CAN NOT BROWSE, REPLACE DISC OR REMOVE WRITE PROTECTION. Is this terminal? Please facilitate with tips.
Answered By 0 points N/A #322256
May be one among 3 things. However, so that it is not the main person, it is also possible that the motherboard works. For a laptop, it is widely connected to the player. When there is an error, it’s time to make a decision and find a reader. On a desktop computer, replace the SATA cable with the optical drive. In this way, you use a completely different SATA cable on a single port. If no one product, have them send a school with a board and cable.
OR
You need to change your hard drive.
