Sdhc card file recovery by Bluetooth
I added sdhc card in my mobile phone. It displays the list of file but unable to open it. I think that I can open them by transferring them through Bluetooth. How can I transfer them by Bluetooth to another mobile?
Best Answer by
Answered By 10 points N/A #155967
Hello Derick,
  • Here is the method to transfer it to other mobile:
  • Right click on the file.
  • Find the option of send then Click on it.
  • Select via Bluetooth.
  • It finds the Bluetooth client.
  • Select the desired contact and press send.
Hope so you will be able to send it.
Take care.
Regard,
Harthy Opera
Answered By 0 points N/A #155968
If you have bluetooth in another phone try one file to send. then see if that file can read to your phone. if not maybe the format of the file is not supported to your phone. can you give me info of what kind of file that wont read to your phone? is it a mp3 file or an application? thank you just give me feedback with it thank you..
Answered By 0 points N/A #155969
Hello Mr. Karpoff.
It would be better if you give us some detailed information about your phone and the list of files. The solution process is not same for all types of phone. Hence, I am giving you a basic solution.
You said your sdhc card can't open the files, that means your phone is unable to read those programs. To send them in another phone you need to switch on the bluetooth option of both phones. Then open the files that you want transfer. Go to the option and select 'send via bluetooth' option. Mark those files and then press send. Your files will be transferred within a few minutes. If you still can't see them, try to transfer them into a laptop or computer.
Thanks for your question.
