A problem with ps3 camera driver windows 7 free.
Hi to everyone,
A problem with ps3 camera driver windows 7 free. I downloaded a free driver for ps3 camera and the installation process was successful but suddenly when I try to launch the camera it doesn’t show any improvement. I can’t still make use of it. Please give some advice.
Thank you.
Best Answer by
Answered By 0 points N/A #165191
Hi Marie Philips,
Maybe you downloaded a wrong driver. Uninstalled that driver and download your PS3 driver here:https://codelaboratories.com/downloads. Then run the program and test it. Or you can use automatic updates to download your device driver automatically.
Answered By 10 points N/A #165192
Check the following before you can run the camera:
  • Check the cable is plugged to the computer port properly.
  • Check that drivers for your device are installed and are up to date.
  • Check that there is no virus attack that is causing this problem.
  • Check that drivers are valid for windows you are trying to install.
I am sure you will be able to run your camera.
Smith Thompson
