NSIS error occurring during software installation
I would like to know how to fix an error that is happening whenever I try to install Circle Dock. I downloaded the software from the internet but I could not install it due to an error. I had to delete the downloaded software and downloaded another copy but still getting this error. “The installer you are trying to use is corrupted or incomplete.”
The installer you are trying to use is corrupted or incomplete. This could be the result of a damaged disk, a failed download or a virus. You may want to contact the author of this installer to obtain a new copy. It may be possible to skip this check using the /NCRC command line switch (NOT RECOMMENDED).
