No signal in my screen please help
My PC does not recognize my screen suddenly. There is definitely black to start with a message "no signal", as if, he was not connected to the PC graphics card.
At first I thought the screen and then have another test that works and still no recognition. So it's not the screen.
Then I thought the graphics card, but it seems odd to me insofar as it has always worked well and I had no problem. Also, I rarely play, it does not really heat up during a lot.
That leaves what? Wiring? The ports of the graphics card? Anything else?
Thank you.
