MICROSOFT VISUAL STUDIO 6.0 COMPATIBILITY WITH WINDOWS 7 OS
I have a Toshiba laptop, I did install windows seven operating system and later activated it. I am passionate about programming, so I installed the microsoft visual studio compiler version 6.0. Unfortunately it has compatibility issues, in that it does not create objects after compilation, I have tried installing microsoft visual studio 6.0 compiler in different partitions but there are no changes. I now use the command prompt to compile C and C++ console programs but I would like to create programs with GUI using the compiler. Is there a solution to my problem?
