Java does not launch when packaged by the Advanced Installer
Hi experts
When I am running a Java product packaged with the help of Advanced Installer, the launcher will look for a proper JRE installation. If nothing is found, this error will be displayed to the user.
I need a solution.
Thanks in advance.
Error:
JRE Not Found
Missing JRE
The Java Runtime Environment(JRE) was not found.Please download and install a JRE(latest version) from:
https://www.java.com/en/
If you have a JRE installed you can browse for it below:
