IIS Web Server Error with SQL Connection
Hello!
I have a local Win 7 and I am trying to install Sitefinity and run with IIS but I received an error as shown below.
I have encountered series of errors such as issue with SQL connection and some access denied errors and I’m happy to say that I have passed on those issues. But now, I can’t seem to fix this error so I really need help.
Message from webpage
Object reference not set to an instance of an object.
OK
Answered By 0 points N/A #142271
This seems not to be your problem. The fact that Object reference is not set for an object in programming. That may mean that some Reference has been created using Object Oriented Programming language but that memory was not allocated for the reference. The object is not found and as such the problem gets close to the programming concept.
That is you may not be able to trace the error, rather the application that you want to open using IIS. In order to get the up dated version you need to post complaint s at the forum of this site.
