Trent Davis
Posted on - 02/06/2013
Can someone help me on where I can find procurement comparison template in Excel? I need this for price comparison regarding bids? I'm using xl 2010 on xp 32 bit sp1. Need this asap. Thanks.
I’m looking for Procurement comparison template in Excel
Hi Trent,
You can easily download the templates from Microsoft Office Online. Check over the different categories on Office Online or get the template you need by entering a keyword or manually searching the website. Once you see the template that you need, then you can immediately download it to your computer.
Based on your needs, I can recommend to use the Bidder comparison worksheet and process template for MS Excel 2010. This template helps you to examine and determine your position against competitors. You can directly download the template here or visit www.office.microsoft.com. You can refer to the screen shot below.
I hope this will help you.
