How to fix community: pod HD500 failed
I was trying to connect my PODHD500 to my mac using POD HD edit but I got the error message when tried to update the firmware from Link 6 monkey. What is actually happened with me? I want to fix this problem as soon as possible so suggest me the proper way to resolve this issue.
I would be grateful to you for any help.
Update Failed.
(Code 80007104) failed write to firmware.
Make sure the cables are still connected and try the update again.
