Games not running well after upgrading Windows vista to 7
I have just reinstalled windows,and my games are not running very well now (they were fine before reinstall).
I upgraded from vista to 7 with different versions of pcsx2.
Every game runs so slowly now and also, there is some problem with the sound plugin.
The error I receive is this:
SPU2-X System Message
Failed to init XAudio2 engine. XA2 may not be available on your system.
Ensure that you have the latest DirectX runtimes installed, or use
DirectX / WaveOut drivers instead. Error Details:(code 0x80040154)
Unknown error code!
OK
Different DirectX runtimes made no difference either.
I need your help.
