File could not be moved to recycle bin” error message
Hi Friends,
Regularly while press Ctrl and backspace to remove the images, I always receive the error message which is attached and you can see
They're no cause provided and no method to indicate the issue,
There is no reason given, and no way to address the problem, so I become upset to keep leaving the images at the back
Does anybody have an idea?
The file named “EA 12898.cr2” could not be moved to the Recycle Bin.
