Duplicate Copy of MS Office
I wanted to add Access 2007 to my workstations so I created an MSP. I also selected the ‘remove all’ button that was set for Microsoft Office Access but when MSP runs, Access 2007 works perfectly but the Microsoft Office Professional that also contains an Access 2003 is still there. Is there anything I did wrong?
Answered By 0 points N/A #174696
Hi Penelope,
There should be no issue having both software, however you can remove one of the versions so it can free up some Hard drive space. On the installation of Office you will notice if it will ask you what software to install on the advance option, on this part it lets you choose which software to install. And again in removing the previous software you can just go to control panel and remove it from there.
