Deleted files reappear after logging in Windows Server 2008!
I have been using Windows Server 2008 R2 allowing users to log in utilizing Netvoyager thin clients through RDP by means of roaming profiles. As a file is deleted by a user, the file comes back again when the user logs back again.
The problem does not happen in the administrator account and any file deleted in it is permanently deleted and never comes back. It only happens in the normal user accounts. But if the user uses a thin client or usual pc connected through RDP, the problem occurs in both the accounts hence neither the user can delete any file nor I can enter their account to delete it.
Please help me regarding this.
I will be really thankful to you.
