Copy The finder can’t complete the operation
Today I got this error in my computer. First time I saw this type of error. What should I do at this time? If somebody knows how to solve this please let me know. Thanks in advance
The finder can't complete the operation because some data (Error code - 36)
Copy
The finder can't complete the operation because some data in “Windows XP-New.pvm” can’t be read or written.
(Error code – 36)
Best Answer by Johnny Mrmarshall
Answered By 5 points N/A #171187
Generally, the drive in which Operating System installed ,there exists some data that requires authentication privilege to access. If you want to copy this authenticated data in windows XP the finder cannot read it for above reasons . So, you get this message. Hope, you understand the reason.
Thanks,have a good day.
Answered By 0 points N/A #171189
Hello WillieMEarls,
Sometimes the product company authenticates some parts of the application, so it is not readable or editable. When you try to copy these files, they cannot be read.
As a result, the Windows copier shows these types of error results, so you try to copy from freeware applications and it never shows these types of results.
I hope this helps you.
