Configure Bluetooth Setup with Pantech PC Suite
Hi guys,
How to configure pantech pc suite bluetooth set up? Bluetooth is very important on sending and receiving files from one device to another and we have to know the proper set up and driver installation process. I hope you can find some ways to guide me accordingly.
Expecting some help, thank you.
Answered By 5 points N/A #183666
Dear user,
I will ask you to download the Pantech II usb drivers on your pc. You can download pc suite software and drivers from this website:
http://www.pantechusa.com/support/link
1. You will have to download Link II & Regular Link software from Pantech site.
2. You have to install Link II software first after installing plug in your phone using a USB cable. All drivers will now be installed for the phone. Unplug the phone after the software you have installed it.
3. Now uninstall Link II PC suite software. This will not work with the link, now restart the computer.
4. Now install the Link 7040 software as administrator, connect your phone and the software will now say it is connected and will work.
Hope this will help you.
Thank you
