CM3530 MFP No EWS After Cold Reset
I forgot my EWS password. To start anew, I performed a cold reset to fix the problem. I performed the cold reset as said, and now even the EWS is not responding. I enter the IP address (entered manually), and no web configuration page appears. I can no longer reach the printer via HTTP/HTTPS, before the reset I could. What is the procedure to fix it?
