Built-in Biometric Scanner in Windows 7
I am using Sony laptop with Windows 7 64-bit installed. The in-built biometric scanner in the computer is not working properly. It start up and stops instantaneously. It is shown as working properly in the Device Manager. I have tried reinstalling the driver and also the security software. Nothing worked. Please suggest a solution to resolve the issue.
Thank you.
