Best windows 7 driver cleaner
I'm facing lots of difficulty after uninstalling some third party softwares. Even it has been already uninstalled, some pop-up messages and error messages coming out at the start up. Even I'm working on W7, still I couldn't find any solution. I searched on google "windows 7 driver cleaner" but there is no any suitable one. Without reinstalling W7, is there any way to do it?
Please let me know..
Thank you..
Answered By 0 points N/A #153168
Issues after uninstalling a 3rd party software normally occurs when,
the program uninstalled is being used by an another program.
It is a system driver
or, uninstall procedure was not followed correctly. Let's say you just deleted some parts of it and did not totally uninstall it.
worst is, it could be a malware or an adware. A virus of some sort.
Because a legitimate software if you uninstall it shouldn't be causing any issues like what you are facing.
download and use this free to try softwares to clean up your system
CCleaner – for leftover files and registry cleanup
http://www.piriform.com/ccleaner
Malwarebytes – for malware, adwares, trojans and rootkits cleanup
https://www.malwarebytes.com/
