AIM.exe says entry point not found
Hey,
I see this error when I try to store data on a server. Its runs perfectly fine with local system I don’t get any error. This error in any way related to dll error. If it is dll error, do I need to re-install AIM? Re-installation might help me to fix the corrupted dll files. Friends suggest me some idea to overcome this error. Badly in help. Thanks.
Error
AIM.exe – Entry Point Not Found
The procedure entry point
?forcedLog@Logger@log4cplus@@QEAAXHAEBV?$basic_string@_WU?$char_traits@_W@std@@V?$allocator@_W@2@@std@@PEBDH@Z could not be located in the dynamic link library log4cplusU.dll.
Best Answer by
Answered By 10 points N/A #186195
log4cplus.dll is a very important DLL from the system and it could have broken owing to installation of certain application or could be owing to virus attack in your system. As you are getting this DLL error from server, I would recommend you to try to register the DLL in the server itself from run (regsvr32 ​log4cplus.dll) where you want to run the application. First make sure that you have all the necessary permission available to install software on a server or register a DLL file otherwise the effort will fetch no result.  Try re-installing/repair the application first. If that works fine the good. Else download the DLL file and the register from run.
