Access violation at address 00404D14 in module ‘dc – unlocker2client.exe’.
Sometimes when I start the application appears this error. I just close the application and run again that works well. What to do to avoid this error? Any help would be really appreciated. Thanks in advance.
Access violation at address 00404D14 in module ‘dc - unlocker2client.exe’. Read of address 0D353724.
Access violation at address 00404D14 in module ‘dc – unlocker2client.exe’. Read of address 0D353724.
OK
Answered By 0 points N/A #176278
    The is this error explains itself as,
Access violation at some address.
The cause of this error can be the programming level error, perhaps the application tries to access some specific address in the memory and tries to copy certain data or change some data at this address in the RAM but currently the memory address is being used by some other application. This type of error usually occurs in applications that are programmed in low level languages.
This can be understood in such a manner that, RAM is used to store data that is necessary for the applications that are currently running. When this application runs it tries to COPY its necessary DATA in RAM but at this time the Operating system is using that portion of RAM for some other application. But later when this program quits after showing this error the operating system frees that part of RAM. So when you RUN this application again it now RUNS fine as now RAM is available for it.
This error can be omitted by,
1. Install an updated version or latest version so that this bug might have been removed.
2. Enhance the RAM of your PC, so there is plenty free for the software to RUN properly.
Hope you understood the problem and got your answer! 🙂
