Archive
Hello everyone, my sound has stopped working with the error code 0xc00d4e85. Please, someone will help! I am operating the PS laptop. Thank you
Read moreA new folder in an existing folder can not be opened. Photos can not be transferred from one folder to another. Photos can not be moved from the camera to the PC. Everyone says, "A sudden error is preventing the process. Windows Error 0x80070718: The available quota is not sufficient to execute this command. "
Read moreI receive error message 0x8024a10a when my MacBook Professional attempts to update Windows 10. The update takes a long time, so it is blocked at seventy-five. I am always joined to a fast broadband service. This is extremely frustrating because it generates this error message and indicates that it should help with Microsoft technical support. However, we tend to come back here and there is no solution! After a while, the update will be retried and the same problem will occur. At this rate, my computer does not get the Windows updates that it wants and a lot of my...
Read moreI still get error code 0x80040304 after trying to target a duplicate if Windows 10 runs on a few days. Ideas? I actually restarted without any changes. Any help anybody can do? Thank you.
As I observed my system’s performance slow as compared to other days, I decided to go a check through all the processes going on in my system. When I opened the task manager I observed a task named sstray exe in execution. However, being unaware of this file and clueless about when I downloaded it. I landed into confusion that whether this file is important for my system to make it work?
Read moreReceived windows update error code 0x8024a105 when attempting to perform the automatic update of Windows 10. This update failed every day in the last 14 days. I tried to fight viruses and the firewall has no effect. Restart the PC several times and still without success. So, the specialist does not want to be included in the registry - the other ideas?
I'm trying to log in to my account, but I received the 0x80a40019 error code. I am trying hard to solve this, but nothing seems to work. Someone, please reply to solve this.
Read moreI have a question or two about cdgenps2. What is this program and what will it do? Do you have to use cdgenps2 if you want to create a CD for PS2? I am trying to create a UNIX system CD for my PS2. I actually have all the files you want, but after I just created them in Associate Degree ISO (with magiciso), the CD did not start (I victimize cogswap)). Do I want to use cdgenps2 to create the files in ISO Associate Degree and then burn that ISO to a CD? Do I still need to...
Read moreI have this disk WD Ext 300 Go for Pat for three years. I recently receive error message 0x800701e3 when I try to copy or send files from the laptop to an external drive. I tried to call completely different USB ports on the laptop with the same error message. I ran chkdsk from the laptop on the drive, but the problem persists. I saved the files from the external drive and formatted the drive. but no success. Any suggestions for correcting the problem? Thank you.
About a week later, I upgraded my laptop from Windows 7 to Windows 10. At first I had no problem with Windows Ten, sometimes | from time to time | from time to time | from time to time | later, later, I turned on my laptop and the Windows Ten brand arrived and there were the same issues. So I waited until everything was finished. Anyway, I restarted my laptop and ironed F9 to check the medical specialty. Almost everything was fine, but only one problem was not correct and it was absolutely my PC footprint. It says...
Read more
