Archive
When I try to install Office, it fails. Usually, an error message tries to explain the cause. The prompt shows office error 30088 13. What can be the reason and how can I solve it?
I have accidentally deleted my folder and now I am not able to restore it. The folder is very necessary for my office work. Can you please help me so that I can restore the deleted folder in one drive?
Read moreA password was asked when installing OpenVAS, but the prompt failed. I have OpenVAS installed and it works well, but I can not act as an administrator. How can I openvas change admin password?
Read moreHow can the RAID option be enabled in MT and DT, but not in SFF 0755? Is not the BIOS and chipset the same? What could I do to make the machine look like a DT? How can I enable optiplex 755 raid 0?
Read moreStarting my database with DBCA displays the following error message:
DBCA_PROGRESS: 2%
ORA-00119: Invalid system parameter specification LOCAL_LISTENER
For troubleshooting, I checked the listener.ora file and the tnsnames.ora file, but I did not find an error. In the file 'initsane.ora' settings: LOCAL_LISTENER = MYD. How can I get through this?
While using my machine I was working on multiple databases, which hung up my system and I had to shut down the machine forcefully due to which my database crashed and I am receiving the error ora00333 redo log error block. How can I overcome this situation?
Read moreWhen I’m installing any kind of software then my computer displays this messages, "A referral was returned to the server." Can anybody tell me what happened and why is this error being showed? Can someone suggest a way to fix this?
I’m using Skype since a long time now but suddenly this error is popping up. Does anyone knows what thus error means? I’m really confused. Is my app having troubles? This is a new computer I bought. Is it possible that my computer is not supporting Skype?
I’ve been searching for the Roboform bar on my phone but the toolbar is missing. I read somewhere that due to recent changes, the toolbar is removed from the top but can still be found at the bottom of the screen. But I think my toolbar might be disabled. Does anyone know how to restore it?
Read moreI just reinstalled my computer and was trying to make some modifications in the security policies. Now I can't install a simple software like screen-captor on my machine. Each time I try to, I receive a message like this "ShellExecuteEx Failed; code error 8235”. A referral was returned from the server."
