Archive
I had formatted my windows. After which while installing the drivers, I am continuously facing error code 40 which says error during unzipping of files.
Read more
I am facing error code 39 while I was installing a device. The error is displaying that, Windows in not able to load the device, the device drivers are corrupted or missing.
Read more
I am facing error code 38 while trying to connect a device to my system. I tried reconnecting it but the same error popped up. It is showing that device drivers are not loaded because an old occurrence of the device is currently in the memory (Error Code 38).
Read more
I was trying to connect USB device to my PC, but an error occurred. The error displayed that Windows is not able to initialize the drivers for this hardware (Error code 37). How can I fix it?
Read more
I was trying to transfer my files from my Mac to a flash drive or a memory card, I got a Mac Error 36 displaying that it is not able to complete the operation because there is some data that is not readable or writable. How can I fix this?
Read more
I am facing an error when attaching an external device. It displays that the system of the computer does not have sufficient amount of information to configure and use this device. Contact the device manufacturer to get a firmware or BIOS update (error code 35).
Read more
I was installing from an .exe file, but the installation did not complete successfully, an internal error occurred and a dialogue box appeared showing error 34. What can I do?
Read more
When I am connecting a device to the computer and trying to run it, Windows is unable to start the device. It is displaying that Windows in not able to determine the resources that are necessary for the connected device. It gives error code 33.
Read more
Window XP is unable to start, even the CD of my Window XP is not working. It is generating an error 32768 and displaying File\i386\biosinf.inf could not be loaded.
Read more
Hey, please help me to fix the psn error code 80710092 in ps3 which states that cannot connect to play station I had been searching for the answer but didn’t know the answer yet.
Read more
