Archive
Often while working on oracle servers we find that oracle databases fail to run because of tmfs file as system wants to resize the tmfs because of system needs and if that is not satisfied database would feel to co-ordinate. How to work around this issue?
Read moreOften while working on production SuSE Linux based virtual servers we need to extend or modify partitions connected to Linux based virtual servers but for the changes to be recognized generally we need a complete reboot. In the real world a reboot means server going offline, how can we get these partition changes recognized without a complete reboot?
Read moreIt is a common problem in all interlinked systems that if not node is out of order the entire chain breaks and the complete system slows down. It is a common problem in Hadoop cluster that if a faulty node or a slow node is there the entire system slows down. How can we work around this problem?
Read moreSome builds of windows 10 kernel especially the earlier builds have some serious audio issues with hardware detection while working with other third party drivers. It has been often reported that windows 10 either thinks that headphones are always connected or simply does not recognize headphones or other audio attachments. How can we try solving this problem?
Read moreThis is an array of errors we come across quite often where error message is generated as report engine crashes as it receives a task from the report server. How can we identify related problems from this section of error reports and solve them?
Read moreOften while working on UNIX report servers we come across an error message which says error REP-50125 has been encountered along with details of the exception and often without it. How can we deal with this wide spectrum report to identify the problem and solve it?
Read moreOften when duplicate processes run simultaneously in a UNIX system report requests from report servers hang up and can lead to serious performance issues. What can be a workaround this process?
Read moreOften while running processes we see that we are running out of ram space for an application we are running or hosting. If we temporarily need some extra ram for a process but only have removable media like pen drives, how can we solve our problem temporarily using pen drives?
Read moreOften while using applications which are taxing on the RAM and the processor some mac operating systems display a spinning beach ball to ask for time to refresh its list of process ids. The problem occurs when this spinning ball just sticks to the skin and refuses to go along with that all systems slow beyond usable level, what can be the workaround this?
Read moreHi. I have been thinking of using the Nortel cs1000 communication server. What is Nortel cs1000 and what are its uses? Also, can you tell me about its features and benefits? Thanks in advance.
Read more
