Archive
I am using Windows 8 and it is driving me crazy that there is no start button. I thought that Windows 8 would have it but it doesn't. I am sure there is a way for me to get a start button, but I would appreciate a small walk-through of what I need to do in order to accomplish this. Thank you.
Read moreI just installed Windows 7 and now I can't play a DVD in my DVD player. It is saying it isn't recognized. Is it because of Windows 7 itself or is it because of something with the installation? hould I remove it and reinstall? Or is it possible it will never work with Windows 7? Thank you.
Read moreI have Windows 7 and it seems to be running slow. I thought it was my wireless but my iPad runs fine with no issues. Is there anyway I can tell if it is Windows or something else? Can I determine the cause of the slowness? Maybe it is a virus but I'm not positive so I want to determine the issue. Thank you.
Read moreI have gadgets that came with Windows 7 and I do not want them. Am I able to uninstall them? If I can, can someone please provide instructions to me on how to do so? I would appreciate your help. Also, if I accidentally uninstall one that I don't want to, am I able to restore it?
Read moreAre you able to customize gadgets, and if so how? I would appreciate any help or tricks anyone can give. Likewise, can I add gadgets to my desktop, and if I can do that, again I need instructions on how to do so. I appreciate any help. Thank you in advance.
Read moreI just bought a laptop to replace my desktop and I need to transfer all of my files. What is the most efficient way to do this? Should I load onto a USB drive and go that route, or should I try something different? Ultimately, if the end result is that I can transfer my files without losing anything, I will do anything, but I was looking for an easy way. Thanks.
Read moreHello, I found a picture from a website I want to use but I want to be sure I do it correct. Do I need to find the website owner and ask for permission? Can I save the photo? Am I able to edit it using a photo editor? It is just an outdoor landscape so no people but it is what I am looking for. Thank you.
Read moreI would like to know more about Flash CS4. What is the use of adding a button in my project? How to utilize the use of button in Flash? What are the attributes available for Text tool? What is a Filter? What are the options or properties included in this? How can I watch my animation? How to execute it and view it real-time? Please give samples on how to export it from Flash to any USB device? Please provide me information what are the file types that I use to inject sound in Flash...
Read more
I would like to know deeper information in Flash CS4. What are layers in Flash? What are the proper usage of it in Flash projects? What do you mean by Stage in Flash? What is the use of Transform in Modify options? What is the use and name of the icon with a chain like appearance? What are the buttons available in Layer window? What is the proper use of the small squares below layer? What do you mean by timeline? How is it created? What are the attributes include in Layer Properties box?
Read more
I am just new in Adobe Flash CS4. I want to know what is the meaning of Symbol in Flash? What are the proper attributes that comes with it and how beneficial using it. What is the use of Paint Bucket tool and Pencil Tool. What do you mean by objects? What is the do you call the small arrow in right lower part of any tool that shows the properties or setup of a shape? Do we have a proper call for it? How useful the gradient colors in Flash CS4?
Read more
