Archive
What are OLED ExpressKey Displays and Intuos4 Medium in it? Can I install Corel draw, adobe free hand for maximum productivity? What is the main working area of Wacom's patented technology? What is Touch Ring function? Can I Zoom, scroll, rotate the canvas in certain software, and adjust brush size, opacity? How can be its display resolution? What is Tilt sensitivity and how does it work? Which software or driver needed to control Intuos4 Pen and Tablet? Thank You
Read moreCan MYOB contacts Synchronize with windows outlook express? What are four levels of account detail in it? Can I disable any unused account? Can I put unlimited number of VAT codes? Is there any option for installment payment? Can I email an invoice to the customer through this software? Can I separately put delivery address and residence address of a customer? Is there low stock item alert available? Describe about its payroll features. Can I export reports to Microsoft excel format? Thank You
Read moreHello, I want to know about Windows Embedded Industry. Basically, I never know about this, so please tell me what exactly Windows Embedded Industry is, why need this and many more questions. Is Windows Embedded Industry with Windows Embedded POSReady? How is it related to the operating system? Which operating system needed to set this up? Describe about requiring system configuration. What are OEMs and ODMs? How is it different from XP operating system? Thank You
Read moreIs it capable of performing of photoshop function such as add, remove, alter the appearance? Can this operate on files? Is Adobe Photoshop Lightroom similar to Adobe Bridge? What is the Library concept in it? Can I create web gallery by using Adobe Photoshop Lightroom and how doing this? Is it supported on XP operating system? How does Panorama Merge utilize? Is it supported by all types of video format files? What is an email directory function available in it? Thank You
Read more
I’ve been having issues with my laptop for the last few months. I noticed that it keeps on getting warmer and warmer even though I am only using it less than before. I tried to check the battery, it is hot and the keyboard part is also hot. What could be causing this issue? Can you provide me instructions on how to resolve it? Can you provide me alternatives on how to permanently resolve the issue? Please help me with this. The fan is too noisy also!
Thank you!
I bought my laptop few months ago, HP Chromebook 11. Since I am always using it and my schedule is always on the go, sometimes I accidentally bumped it in the door and the edge of the table. That pierced and made a hole in the right part of it. I still don’t have budget to replace it. I just have to cover it so no one will notice the damage. I am quite humiliated with this, I just want to know, is there any way that I can patch the damaged part of my laptop?...
Read more
Hi!
I have an android phone that I just bought last year, say at least 8 months ago. I am annoyed with my USB connectors because it is partially peeled in the near connector of the “Male-type” part connector. If I will be able to position my Android phone properly, it will connect to my laptop and desktop. It is annoying that I will move the phone, it will disconnect and the files I am downloading will stop. This happens to me multiple times. How can resolve this? Can you...
I recently formatted my desktop with Windows 8. I have partitions and the videos were all located in one partition. I reinstalled VLC media player from a site. Everything were installed successfully. I tried to play the few movies but it keeps on showing me pixelation and “white” disturbances in the screen. It happens often times. I closed VLC player and tried to play again a movie, still the same. Can you show me how to resolve this issue? Can you provide me alternative resolution for this?
Thank you very...
Hello!
I would like to ask if you can help me resolve issue with my desktop problem. I just recently formatted my computer. Everything works fine only but the computer and monitor. Keeps on turning off if I am not doing anything and will stay off. I can’t bring it out from hibernate mode. Can you help me fix the problem? Can you tell me how to resolve this? Can you provide me also alternative resolution on how to keep this from happening again? Thank you very much and have...
I connected and installed a printer for our working area. We tried to print with this printer from LAN but nothing happened. Everything were all properly connected and followed the manual on how to connect it with LAN. But still the same. Can you provide us resolution for this problem? Can you provide me alternative solutions for this device? Can you give me pointers on how to prevent this from happening again? Thank you very much and have a nice day!
Read more
