Archive
Hello, I have problems with Autodesk Revit 2015. Sometimes the model does not show and parts of the interface are black until I hover over with the cursor. My computer specs are Intel Core i7 2.50Ghz 16GB RAM, NVIDIA GeForce GT 750M. I have been minimizing and clicking on different views for it to show up.
Thank you.
Hi, guys. I have been trying to figure out some questions about SharePoint that I would like assistance.
My 2013 copy of SharePoint does allow users to copy files out of the SharePoint server. Have any of the newer versions introduced a feature that disables this?
How do you people deal with other users not putting their files onto your SharePoint server when they should be?
Hi, I am replacing our home desktop PC by buying all the components then building it up. I could go buy one pre-built given that my experience and background with PC’s is minimal to none, but I do want this challenge. I have bought the Intel i7 4970k Crucial Ballistix 16GB DDR3 RAM and got the Gigabyte Z97X Gaming 3 mobo. I would like to build the best and biggest PC I can, I have been reading about bottlenecking too. I would like to know if mobo is good for my needs and if it...
Read morePeople use the Windows disk cleaner feature in order to delete unnecessary files from their PC if they are on Windows. I'm on Mac and I need to find out the disk cleaner for Mac. Which is the disk cleaning software for Mac that can delete all the unnecessary files? Any suggestions?
Read moreI used Ubuntu as a live user last night and I downloaded many software for it including Wine, AbiWord etc. Today, I checked my hard drive and those software were nowhere to be seen. They were not on the CD either. Where have the software gone? Aren't the data of live session saved?
Read moreI'm using Adobe Photoshop. I use it to edit my photos and it is a very good software for photo editing in my opinion. I want to find out the difference between type tool and note tool. What are each of the above mentioned tools used for in above mentioned program.
Read moreI have heard about SATA and PATA. They are the cables available for data transfer on the motherboard. What are the major differences between SATA and PATA? Which one of them is fastest? Which one is used in the Play Station 4 and XBOX ONE? What will be the data transfer wire for motherboards?
Read moreI have a 500GB hard drive and I have 3 partitions on it. One has Windows 8.1 and I would like to install Linux on the other drive. How can I change a logical partition to a primary partition without facing any problem. I used EASUS Manager but it nearly bricked my PC.
Read moreI'm currently on Windows 7 and I have setup voice recognition for my system. Unfortunately, I'm unable to log on to my system because Windows is not recognizing my voice. Is that even possible? How can I gain access to my system after all, I'm rejected by my system. Any suggestions?
Read moreI'm currently on Windows 8.1 and I need to setup face recognition for the security of my system. I have a Webcam that is the most important hardware for my will. How can I setup face recognition on Windows 8.1? Is this security type reliable enough? Are there any software with this feature?
Read more
