Archive
I am facing sound problem in my computer because my IDT high definition audio codec code 10 not working and it is not fixed. How can I solve this?
Read moreError message: remove disks or other media press any key to restart. Unable to boot from the pendrive. Can anybody help me to solve this problem?
Read moreI am facing sound problem in my computer because my IDT high definition audio codec driver windows xp is not working and it is not fixed. How can I solve this?
Read more
I am using windows xp. And I am facing a following error causing the blue screen:
IRQL NOT LESS OR EQUAL
Can anybody help me? How can I solve this problem?
I am facing sound problem in my computer because my IDT high definition audio codec not working and it is not fixed. How can I solve this?
Read more
I am using windows 7. And I am facing a following error causing the blue screen:
I am facing sound problem in my computer because my IDT high definition audio codec windows xp is not working and it is not fixed. How can I solve this?
Read moreI am facing sound problem in my computer because my IDT high definition audio codec not working and it is not fixed. How can I solve this?
Read moreHello! I just installed Windows 7 on my computer and I turned off the automatic windows update. But the icon on the right bottom corner of my desktop keeps on saying to turn on the windows update. Its from the windows action center. Is the automatic windows update necessary for the computer or not?
Read moreHello! I am thinking of starting my own search engine. Initially it will be very simple but I want it to become mature with the passage of time. What kind of data structures should be used for the search engine. One that I know is the graph data structure, but I am sure other data structures should be used. Links for reference and help will be appreciated. Thanks in advance!
Read more
