Archive
I lost the menu bar now I tried many ways to recover it but I am unable to do so. Some time it appears but a I remove the mouse from that it goes. Please anyone can guide me to get it back permanently. So it will make my easy.
Read moreI have lost my Window 7 user login password. I can login through the guest account but now I do not know the password of actual account. I used Ophcrack to create a live CD to find the lost password, but it said password not found. Is there any other software which I can use to recover CPU password.
Read moreI have a Lenovo PC with 1TB HD and 4GB RAM. I used it daily for my work. Suddenly, I was unable to open the Windows Login Screen. When starting it, a black screen opens and then it turns off. I don't know what happened and I even don't know how to fix this so I cam here. Can anyone help me?
Read more
My computer is a Dell Inspiron and it has an issue on the USB port blocking. Any type of device that's connected to it will show an error of: "You have no access to this type of service...". I tried the regedit command of USBSTOURAG, but it doesn't work. How can I resolve this? Can someone help?
Read moreWhen using my microphone on any means, it emits a intolerable noise. I tried various microphones, changed my PC but the noise was still there. My old motherboard has Realtek and there is an option to control the noise. But when I changed my motherboard to ASUS with VIA VT1705 HD, there is no option for this. Are there any other way or program that I can use to control the noise on my microphone?
Read more
I bought a flash drive with some music in it, it recognizes in the cd player of my car., but when I connect to the computer i can not access the folder with the songs, a lock icon appears with this "aux.black 1000.5d573c". When I try to change to read-only, I get a "Error Applying Attributes" message. The type of folder is this "file folder (. {2559a1f2-21d7-11d4-bdaf-00c04f60b9f0})" and opens with "common DLL Windows Shell." Wanted full access to folder, does anyone have any solution without formatting?
Read moreI recently configure my D-Link DI R610 router. Since then, I was unable to access the Internet on my laptop and mobile phone. An error is showing when I try connecting. It says, "Windows cannot communicate with the resource or device (DNS primary)".I used various DNS servers but the error is still occurring. How can I resolve this?
Read more
I purchased a new Samsung Galaxy S5 that comes with Android OS. Few weeks later, my friend bought a new Galaxy S5 too. But I notice that his device has the latest updates and it comes with several new features. I want to know if there's a way that I can update mine. If so, please tell me the step-by-step instructions that I can follow. Thanks.
Read more
At present, my laptop is running Windows 8 with 4GB RAM on it. I looked on my Task Manager and it shows 50MB is already used but yet, it also says, 85 to 93% is also used up. I'm not quite sure which is which and it makes me so confused. Also, recently, when I start my laptop, the RAM is normally around 27% is used with some processes. But this time, it's 90% without the processes. Is this an issue with my RAM? What is taking too much memory?
Read more
My problem is about my Dell S2440L monitor. It is causing the computer to crash after few hours of usage. I tried connecting the monitor to multiple desktops and laptops with different versions of Windows and Ubuntu. They all crashed so I searched for the latest drivers for each OS, but it consistently crashing. Are there any other solution aside from getting the latest drivers?
Read more
