Archive
Hi Everyone,
I am trying to unlock some of the Movie Plus features on MoviePlus X5 and find that MoviePlus can't unlock some features automatically. I get a ‘cannot connect to feature unlocking server’ message when attempting to unlock. I checked my internet connection and found that it is working normally and that its speed is good as usual. I did not get any warnings or error messages from my firewall when trying to unlock but all the same I attempted automatic unlocking after disabling my firewall settings temporarily. Still I have had no luck and this problem persists. I...
Read moreI want to know how I can add a watermark in PowerPoint 2007. Can someone please tell me the procedures on how to do it correctly? I need it for my school project. Any help will be highly appreciated. Thanks!
Read moreHello,
I have been trying to install Apple Final Cut studio 3 and I keep getting this error message saying that the source media is damaged. I am working on Mac OS X 10.5.1. Someone suggested trying to clean the disk I am trying to install from using a dry lint free cloth. I tried this method and found that nothing changed. However when I tried to use the same disk to install on an iMac G5, there are no issues!!! But on my 10.5 machine, once the audio content 1 disk is done with, it asks for the original...
Read more
I hope someone can help me figure out what is going on here. I have been trying many times to install the app Perfect 365 from windows store but it keeps on failing to install with an error has occurred message. This message gives me an error code but otherwise it is not very informative as to what might be the trouble and what could be done to fix it. I have attempted installing several other apps and all of them installed without any issues and are working fine too. I am clueless as to what might be blocking...
Read moreHi Everyone,
I am trying to export a file into ProTools 8 from Nuendo 3.2 and I am unable to do so as I receive the following error message when attempting to do so. I chose to Export from File Menu after selecting the track as new AAF/OFM and then this message pops up. The error message gave me an option to disable Elastic Audio processing in order to render the changes. I tried setting all the elastic audio to render only mode. But still, I seem to have no luck, this error keeps appearing again. I need the elastic...
Read more
Hello Friends,
I keep getting an error message from AutoDesk Exchange Store every time I attempt to launch 3ds Max 2014.The message reports that it ’failed to find any "RuntimeRequirements" nodes under "ApplicationPackage" node in "C:ProgramDataAutodeskApplicationPluginsCreate BOM.bundlePackageContents.xml". Please check its format.’ I tried re-installing a couple of times worried that this error would cause 3DS Max to crash or affect its functionality. When I kept on getting the error even after this I decided to close the error window and try to go ahead. And I found that, other than getting this annoying message, I didn’t notice anything wrong when...
Read more
I have been using DrawPlus X5 for about 5 months now and everything was working fine. Yesterday, I applied the latest patch, and now I find that I can't save my files in DrawPlus X5. I keep getting this warning 'An unknown error has occurred whilst accessing an unnamed file'. I've tried pressing Ctrl when opening to reset defaults but this warning still persists. I tried to uninstall the application and reinstall again and it worked fine without the patch. Again I tried installing the patch and things seemed to work fine for a few days but now I...
Read more
Hello Everyone,
I am trying to quantize elastic audio events on a track using ProTools 10 and whenever I attempt this, I get an error ‘Could not complete MIDI Groove Quantize command’. I created a groove template from an acoustic guitar track by choosing the Beat Detective event and selecting the audio and choosing to extract groove template. Then I clicked ‘Capture Selection’ from selection menu and clicked Extract. Then I enabled elastic audio in acoustic track, change it to warp and try to quantize and I get this error. What is causing this error? Did anyone face a similar...
Read moreHi All,
I have been using PCDJ for quite some time now and I am quite impressed with this superb software. A few days back, I downloaded the PCDJ beta with new CDG engine and was trying out the new version when I encountered this problem. I am trying to load a BMP image in the CDG area of PCDJ, a ’Missing operand’ Syntax Error gets displayed and even though the error gives a continue option, clicking it wouldn’t give any result. Is this an issue with the new 0.8 build? I am using this build along with an earlier...
Read moreI'm trying to run FileMaker Pro 12 on my Mac OS X 10.7.5 but it always ends with an error. I know that Mac puts a new feature that will prevent the users from installing software from unidentified developers, but I want to know how I can install this without breaking any rules? Please help me.
FileMaker Pro 12.mpkg" can't be opened because it is from an unidentified developer.
Your security preferences allow installation of only apps from the Mac App Store and identified developers.
"FileMakerPro 12.mpkg" is on the disk image "fmp_12.0.1.183.dmg". Safari downloaded this...
Read more
