Archive
Hi Pro,
I am hardware person; I did this installation many times. But I never faced this kind of error in the past. That was all smooth, easy and error free. The Oracle Database installer throws an error, most of the things I don’t understand. Overall I came to the conclusion it is missing some dll files, you can see it image 1, I tried to ignore the error and continue but then another error pops up. Sqoras32.dll failed to load, howI load this dll;you can see this in image 2. The third image tell u everything, I stopped the...
Read moreHello tech experts,
I tried this Web service Software factory installation for couple of times, like installing and re-installing, nothing worked. The installation went through almost to the end, but it failed in registering ASMX guidance package. May be the package is corrupted or missing some files. I am not sure what is going on. Please help me to fix the error. Your help is great. Thanks.
Error :
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2869.
Read moreHello trouble shooters,
When I try to start the connector on the client computer it gives me an error message. The message states that cannot connect the computer, I am not running any software installation either in the client machine or with the local one. Then what might be the reason? I tried the common method of restarting both the machines, but no luck. Please help me to establish the connection, your help is appreciated.
Error:
Cannot connect the computer to the server because either another software installation is in progress, or, the computer has a restart pending....
Read moreHi folks,
When I try to activate the NetgearProSafe VPN Client on windows 8 failed with an error message. I think the installation went pretty good and problem is with the activation. Am I using the right version? Do I need to run it compatible mode for activation? Please enrich me with some suggestion. Thanks.
Error :
Activation not completed
Activation Error 70: Internal error.
Please retry the activation later.
Read moreHi friends,
I bought the apple gadgets like iPod and iPad, so I am trying to install the iTunes in my system. When I tried the installation went well and good without any error but the error pop up stating the installer encountered error before iTunes could be configured. What might be the cause? I tried again by restarting the system and re-installing iTunes, no luck. Anyone experienced this before, suggest me some solution. Thanks.
Error:
iTunes Installer Completed
The installer encountered errors before iTunes could be configured.
Errors occured during installation. Your system has not been modified.
Please run the...
I am stuck up with error diagnostic capture; it failed to start data capture. I don’t understand what is going wrong in Multireader? After this error message I double checked the file permission it is perfect. Do I need to check the properties? Totally blank, help me to sort the problem and to find the cause of this error message. Thanks in advance.
Error :
Error Diagnostic Capture
Failed to start diagnostic data capture. Please check permission on file C:Multireader_rdd.tmp
Read moreHello Experts,
I am a good user of Arcsoft Showbiz, while I am trying to capture a video file I ended up with this fatal application exit error message. I got stuck up with this, not able to continue further. Am I going wrong anywhere? Any other application is triggering this error? I am doing in windows 7 operating system. Please guide me to solutions, help please.
Error :
Missing Ordinal C:Program Files (x86)ArcSoftShowBizcomdlg32.dll->SHELL32.dll:148
Read moreI'm running Mac OS X Mountain Lion. I am getting a kernel panic error when I restarted my computer. As far as I remember, I shut it down properly the last time I used it without any issues. But when I opened it today, it has an error. And then when it restarted, the same error will just showed up. How can I fix this?
You shut down your computer because of a problem.
If you want to open the applications that were open when you shut down, click Open.
If you do nothing, the computer will continue the...
Read moreThe DirectX C++ app I have here can be compiled but it can't work. It gives a runtime error as shown below. I am running Windows 8.1 and based on dxdiag, everything are running correctly with DirectX 11. How can I fix this?
ERROR
>ORIGIN:
InitializeDirect3D: D3D11CreateDevice(...)
ERROR:
The application requested an operation that depends on an SDK component that is missing or mismatched.
Read moreI just migrated to Windows 8 from Windows 7 on my ASUS PC. My problem is when starting the Wi-Fi Go, I am facing an error from AI Suite 3. I searched for the exact error I've got on the web but I found nothing useful. Can someone please help me with this?
The error is:
Aisuite3
Access violation at address 0042D234 in module 'AISuite3.exe'. Read of address 00000018.
Read more
