Archive
I am having issues on setting up connection to my website through Local / Network option. The website is under Windows 2003 server while Contribute is in the other server. These two machines are networked with admin access. However,  I am receiving error. I already mapped the shared network to the local drive. How can I fix this?
Contribute cannot verify your connection information. /public_html/
Please contact your administrator for assistance.
OK
Read more
The installation of MBAM on SCCM 2007 works just fine. But on one workstation, it fails and when I try to run the MBAMClientUI.exe manually, the error below appears. I don't know what is missing or what's been going on but I hope someone can help me figure it out. I need some help please. Thanks.
Error
BitLocker drive encryption has a problem and must close.
BitLocker will close now. Contact the help desk of your company if you need additional...
Read more
Hello folks,
When I try to launch XAMPP 1.7.1 win 32 in the system I facing some difficulty. The download was good, without any issue. Then I start the installation it went almost to the end like 99% but all of sudden I got this error message. I just followed the instruction to install the software. Don’t understand where I went wrong? Please help. Thanks.
Ports 80 or 443 (SSL) already in use! Installing Apache2.2 service failed
OK
Read more
Hello tech folks,
I have been facing this problem for quite some time, getting tired of this error. I get this weird error message when I work around with Eclipse. For more information, I have Eclipse and jdk installed in Windows 64 bit operating system. How can I solve this error? Please do not say I need to reinstall everything. Help please. Thanks.
Java Virtual Machine Launcher
Error Could not create the Java Virtual Machine.
Error A fatal exception has occurred. Program will exit.
OK
Read more
Hi Brainy,
I love to play games in the computer, so I installed EverQuest II. I am getting a weird error when I play EverQuest. The error sounds like missing some files in the computer. I tried the common methods uninstall and reinstall but nothing seems to work. Do I need to download the DirectX? Please suggest me some solutions to solve this error. Thanks in advance.
EverQuest II has detected an unrecoverable error and must shutdown.
G:liveeq2frameworkcoredevicesDirectX9RenderDevice.cpp (6182):
DirectX Error. (E_FAIL)
017efde7
Read more
Hi Experts,
I am getting this error message ‘cannot find Java 1.5 or higher’ when I run a simple program in netbeans. This error is not happening when I run it in the Java_Home environment. What might be the problem in this case? Does anybody facing this problem? Not able to track the error, please help. Thanks.
Error
Cannot find Java 1.5 or higher
Read more
I was creating a scheduled scan with ClamAV's Immunet through the domain user's credentials. I'm not sure why it appears since it doesn't look like a domain credentials. Please tell me how to fix this. I need to schedule a scan since I'm not always at home. Thanks.
Error creating scheduled scan.
An unknown error has occurred.
OK
Read more
I am facing a terrible problem with NetBeans when I try for an update. However, it fails every time, leaving a message ‘Reference problems one or more projects resources could not be found’. More information JSF projects with NetBeans using TortoiseSVN (Subversion). How to find the jars? How to fix the Resolve conflicts in the project? Please help me.
Open Project
Reference Problems
One or more project resources could not be found.
Right-click the project in the Projects window and choose
Resolve Reference Problems to find the missing resources.
Read more
Hi Tech savvy,
I am not able to run a program in NetBeans. I get a weird error message saying ‘one or more projects were compiled with errors’. If I hit the ‘Run anyway’ button I get an output else if I hit the ‘cancel’ button I get an error. This error appears every time, I run the program. Friends please suggest me some idea to overcome this error. Your help is great. Thanks.
Run Project
One or more projects were compiled with errors. Application you are running may end unexpectedly.
Read more
Hi Brainy,
I know the source of the problem but not able to fix it, anyone can help me. I have a CD which is slightly damaged; I copied some files from it but still some files left behind. I get this error message ‘cannot copy freedom: Data error (cyclic redundancy check)’ then the process is aborted without any option. Is there any other way to copy files from damaged CD. Please help.
Error Copying File or Folder
Cannot copy Freedom: Data error (cyclic redundancy check).
Read more
